How to adjust Clutch Cable
Old Sep 20, 2008 | 02:24 AM
balanis03's Avatar
Default How to adjust Clutch Cable
Ok i got my new clutch cable and clutch handle and before i installed them i checked them out and it all matched fine handle was the same and the clutch cable is the same length but for some reason when i adjust the cable and when i press the clutch in it wont go in gear. Does it have to be in a certain gear when you put it on. Ive already tried everything and i even put back the old cable and didnt want to work and it was working before i put the new cable cause i rode it around the block. Can someone please give me some tips on the best way to adjust cable on Jet 250. Thanks in Advance
Old Sep 23, 2008 | 05:53 AM
hotblooded's Avatar
I am not real familiar with this model, I can only tell you that I replaced a clutch cable on the Blaster and had to open up the clutch case and adjust it in there first. On the Blaster there is a small screw right in the middle of the clutch with a lock nut on it. Just loosen up the nut and give it a 1/2 turn out and tighten up the nut while holding the srew with the screw driver. Sorry for the mis info if it isn't the same.
Old Sep 23, 2008 | 11:47 AM
balanis03's Avatar
Thanks for the info i actually was thinking that i might have to adjust it in there but well see if i can adjust this weekend thanks for the info.
ghost civic
Jan 15, 2020 07:43 AM
Cummins Driver
Sep 11, 2019 01:22 PM
GregM
Mar 6, 2018 06:53 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
timster911
Jul 13, 2015 01:57 PM
