Carb won't drain
Old Sep 20, 2008 | 11:23 AM
jdlr's Avatar
Default Carb won't drain
I am having problems starting my Magnum 325 4x4. I have a new spark plug, and the battery is good. I want to drain the fuel, but when I loosen the screw on the bottom of the float bowl, only a small amount comes out (much less than I would expect). I have the dial turned to "on", and the drain tube is clear. I think there may be sediment blocking the drain. Any suggestions? Thanks.
Old Sep 20, 2008 | 02:28 PM
MagnumPO's Avatar
probably gonna have to take it apart and clean it, if you dont feel comfortable with a complete rebuild you could try taking the bowl off and looking around. you will need to come up with another gasket though.
Old Sep 20, 2008 | 02:41 PM
jdlr's Avatar
Thanks. Can the bowl come off from below, or do I have to take the tank off? Is this the time to do anything else (needle valve etc)?
Old Sep 20, 2008 | 02:48 PM
MagnumPO's Avatar
I've taken mine off before without taking the whole carb off(magnum 500) I dont know about yours. If you have the means to do a complete rebuild then I would just to have it out of the way.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
Shifts
Jul 3, 2015 07:59 AM
