Ring Postion on a Blaster
Hello All,
I have no instructions for installing new rings and the book sucks. My rings can be installed one of two ways. Which is correct. These are side views
DIAGRAM A
Piston top
ring / \ ring
LOWER CRANK
DIAGRAM B
Piston top
ring \ / ring
LOWER CRAANK
DIAGRAM A
Piston top
ring / \ ring
LOWER CRANK
DIAGRAM B
Piston top
ring \ / ring
LOWER CRAANK
what book do you have? get the haynes atv shop repair manual. http://discountautorepairmanua...=darm&Category_Code=YA
generally the bevel goes towards the side the ring is doing the work on. for example on a four stoke your top ring is the compression ring so the bevel goes up. the second ring is an oil ring so the bevel goes down towards the oil.
