Ring Postion on a Blaster
Old Sep 22, 2008 | 12:01 PM
chuckneste's Avatar
Default Ring Postion on a Blaster
Hello All,
I have no instructions for installing new rings and the book sucks. My rings can be installed one of two ways. Which is correct. These are side views
DIAGRAM A
Piston top
ring / \ ring
LOWER CRANK
DIAGRAM B
Piston top
ring \ / ring
LOWER CRAANK
Old Sep 22, 2008 | 07:04 PM
cadillacdude1975's Avatar
what book do you have? get the haynes atv shop repair manual. http://discountautorepairmanua...=darm&Category_Code=YA
Old Sep 22, 2008 | 07:37 PM
chuckneste's Avatar
Ok,
The company has replied back.
Diagram B is correct. It will cause better compression
Old Sep 22, 2008 | 10:55 PM
skj283's Avatar
generally the bevel goes towards the side the ring is doing the work on. for example on a four stoke your top ring is the compression ring so the bevel goes up. the second ring is an oil ring so the bevel goes down towards the oil.
Joe454
Nov 20, 2020 01:19 PM
Ahtatu
Sep 28, 2015 12:14 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
bvolks
Sep 13, 2015 12:57 PM
