06 Sportsman 500 efi
Old Sep 23, 2008 | 11:27 PM
Rush25's Avatar
Default 06 Sportsman 500 efi
Hi,
I live in Phoenix AZ and store my quad in the garage over the summer months. It's just too darn hot to ride in the summer here in the desert...112 - 116 is just way too hot unless I go north to the mountains.
Anyway the gas went bad in the tank. I drained the bad gas, replaced the fuel filter and re-fueled with fresh gas but can't get it started. When I spray starting fluid in the intake it runs for a few seconds which tells me it's getting spark and the electrical checks out okay. But when I disconnect the gas line from the injector no gas is present. I'm thinking it's the fuel pump.
Can someone tell me when the pump is located, how to access it and how to diagnose it? I would much appreciate it.
Thanks,
John
Old Sep 23, 2008 | 11:42 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
The pump is inside the tank........I heard on here the tank and pump are one unit(wait for someone with a EFI to correct me)...........Did you make sure the fuel shut off lever is NOT turned OFF!!!...........Caper.........
Old Sep 23, 2008 | 11:50 PM
Rush25's Avatar
Does anyone know if just the pump can be replaced? As far as I know there is not a shut off valve so if there is one it would not be shut off.
Old Sep 24, 2008 | 12:02 AM
Pump is in tank,do you hear pump priming up when key turned on? If no gas at fuel rail when line disconnected and engine turned over then can possibly be faulty pump.
Old Sep 24, 2008 | 12:15 AM
Rush25's Avatar
Can the pump be replaced without the entire tank being replaced?
I do hear the pump prime when I turn the key but no gas at fuel rail.
Old Sep 24, 2008 | 09:38 AM
Spdecat's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: caperinmuskoka
The pump is inside the tank........I heard on here the tank and pump are one unit(wait for someone with a EFI to correct me)...........Did you make sure the fuel shut off lever is NOT turned OFF!!!...........Caper.........</end quote></div>
Just another reason why the carb is so much better fuel pump under left front fender a 5 minute replacement [img]i/expressions/face-icon-small-smile.gif[/img] Dam you could do it on the trail [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 24, 2008 | 10:58 PM
<div class="FTQUOTE"><begin quote>Originally posted by: Rush25
I do hear the pump prime when I turn the key but no gas at fuel rail.</end quote></div>
Tank and pump sold as a unit,hope this is not your problem. Good luck
Old Sep 24, 2008 | 11:40 PM
I remember a post on here a while back .......Someone gave a Auto Part number for a direct replacement for a Quad fuel pump(Polaris I think)..........Anybody remember reading that post?..........Caper...........
Old Sep 25, 2008 | 12:45 AM
TLC's Avatar
TLC
<div class="FTQUOTE"><begin quote>Tank and pump sold as a unit,hope this is not your problem. Good luck </end quote></div>
That is one stupid design idea on Polaris part.[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Sep 25, 2008 | 01:03 AM
plumbob's Avatar
Check the screen on the fuel pump inside the tank,it could be clogged.If your pump is shot there is some aftermarket ones available.Airtex E8198 or Carter E7000.I believe they use a different pickup hose so you may have to use the factory one.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
