blaster blown head gasket
Old Sep 24, 2008 | 06:39 PM
blasterman831's Avatar
Default blaster blown head gasket
i have an 10 blaster and i blew the head gasket is this comman for yamaha bikes and atvs.
Old Sep 25, 2008 | 06:32 AM
hotblooded's Avatar
We blue alot witj our okd engine builder. Since I have found the new engine dud we havent lost one and making a ton of hp.
If you have questions give bud a call 715-307-3422 and he would be more than happy to help you. Just tell him Todd W told you to call......let me know
Old Sep 25, 2008 | 09:40 PM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
2 strokes do this all the time. You should be pulling the jug once a season and changing rings and head gaskets anyway. Pistons about every two years or so... If you race it or spend a great deal of time at full throttle, then you will doing htis even more often. When I was much younger on a 250 race bike, I used to re-ring every 3 races. The motors are more complicated now, but the old blaster two stroke is as simple as they come. When buying the parts, plan on buying extra head studs at the same time, yo uwill invariably break one every time the motor comes apart. You do not have to split the cases, Just pull the jug and leave the bottom end alltogether. Stuff a rag in teh hole as you pull it apart so you don't get any dirt and junk in the case. If you need anew jug and piston, now is a good time to upgrade.
Old Sep 27, 2008 | 12:48 AM
hotblooded's Avatar
Dragginbut, you are right about the re-ringing and putting new pistons in. We run a 13 show series so counting practicing would be 39 races. We have the cylinder coated so we don't re-ring, we do check the compression after each show. We typically run 135-130 psi, if we drop down low we just replace the piston which this year was once. You know as well as I that the piston slop is probably the largest contributing factor in broke pistons. After alot of races and maintenance that is questionable is costly and you learn quick that air filters clean easy and are cheap. One thing that we haven't done is broke or pulled a stud, I did once when we first started racing but was my own fault torqueing it too much.
fd24
Jan 16, 2019 08:59 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
