redcat kazuma 110
Old Sep 28, 2008 | 12:07 PM
rigidshuvel77's Avatar
Default redcat kazuma 110
kazuma 110 engine ajusted valves to .004 have good spark getting fuel but will not start, sputter or anything. one of the three bolts on the cam gear was missing so i took the head and cylinder off and was able to retrieve the bolt i think it got caught in the chain and caused a major timing jump. i reassembled with TDC mark and guessed at the cam timing. It only has one mark on the cam gear and one mark in the case but it also has two small tabs that the mark on the cam gear could be lined up between. Can anyone help? should i be looking at a different problem? is there a way to adjust igntion timing? i usually only work on harleys and this little quad has me stumped any help is appreciated
Old Sep 29, 2008 | 08:18 AM
pickle0400's Avatar
Im having the same problem with my sons 50 meerkat. Replaced rings having trouble with cam. If you get an answer on the cam could you let me know. Thanks
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
predtldrider
Mar 29, 2005 09:03 AM
flmedic911
Jan 20, 2005 06:08 PM
