HELP!! 98 blaster will not shift
Old Sep 28, 2008 | 03:52 PM
newbuilder's Avatar
Default HELP!! 98 blaster will not shift
blaster will not shift. Sometimes i can get it into 1st . Were should i start?
Old Sep 29, 2008 | 02:39 AM
hotblooded's Avatar
It isn't a real common problem but it does happen some, and that is the shifter shaft gets bent or broke. It usually breaks on the clutch side were the little hook is. This is the first place I would start.
Old Sep 29, 2008 | 12:23 PM
raptorider's Avatar
ive also seen people wear out the shaft that the gear shifter is connected to. the teeth get worn out if the shifter was not on tight.
hope that helps.
95wolv
Sep 27, 2024 12:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
nastyblaster100
Sep 13, 2015 01:19 PM
