honda atc200m 1985 magneto, how to?
Old Sep 30, 2008 | 05:11 PM
meneermalik's Avatar
Default honda atc200m 1985 magneto, how to?
I have a honda 1985 200m ATC. I'm pretty good at doing things mechanically but I need to know what to look out for. I've been slowly checking the ignition system to find the problem. A local shop that sells and repairs ATC's told me I should check the magneto. I have a 200 page repair manual but cant find anything that relates to that. Is it also called the pulse generator? Where is it? And what exactly should I be looking at or for when I do inspect it?
Thanks for all the help.
Old Oct 1, 2008 | 12:52 PM
tdenney's Avatar
It has a CDI ignition, capacative discharge ignition I believe is the correct term, pulse generator may term in the manual. The cover is on the left side of the engine as you are sitting on the 3-wheeler. You should have no problem finding that in your manual. You will probably want to inspect the rotor gap make sure the advance springs are not broken (which seems pretty common).
Old Oct 4, 2008 | 07:23 AM
HondaMechanic's Avatar
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
Steeldon
Sep 8, 2015 10:51 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Jason Campbell
Sep 7, 2015 02:25 PM
