Tecate 4 synthetic oil for break in??
Old Jan 30, 2001 | 09:56 PM
letitsnow's Avatar
Can you use synthetic oil when you break in new rings? I know that on 4 strokes you aren't supposed to. I'm kind of new at this 2 stroke stuff. Also, this is kind of a dumb question but, How tight should the exhaust springs be that hold the pipe onto the cylinder. I am concerned about the springs pulling through the aluminum on the cylinder. Thanks in advance.
Old Jan 30, 2001 | 10:50 PM
drlaney's Avatar
I would say the same logic would hold true for the rings in a two-stroke. Most engine designers feel that synthetics inhibit the "bedding" of metal surfaces during the break-in period. Bedding is the process by which imperfections in the construction of a metal part (For example, due to gravity it is impossible to produce a perfectly round surface.) are worn away leaving a closer-to-perfect form. I see no reason why rings would be any different. In fact, they may very well be the parts that depend most on bedding.
Old Jan 31, 2001 | 01:44 PM
banshees4ever's Avatar
A friend of mine used Power Plus, 100% synthetic in his Takate 4 after having motor work done to it and it broke in fine and runs awesome.
Old Jan 31, 2001 | 06:15 PM
drlaney's Avatar
Just keep in mind that differences will not appear until long after the break-in period. The rings, rod bearings and camshaft are more likely to last longer in the engine that was handled properly during break-in. In other words, they will produce higher levels of horsepower when other engines begin to fail.
Old Feb 5, 2001 | 05:48 PM
letitsnow's Avatar
Will the rings seat in ok on a 2 stroke if you use synthetic oil?? I ask because I now have the power vavles all cleaned up, and I don't want to get them full of **** again.
Old Feb 5, 2001 | 08:24 PM
greencow's Avatar
I have 3 tecate 4's make shure the oil you use is for a power valve or kips motor such as H1R by Bel-Ray or if you have a favorite use that mine is Ben~ol by klotz i use H1R on occassion so power valves dont stick this is more critical for trail riders than WOT riders go to CT RACING for a tech artical on break in for 2 strokes, Air filter is the most important for any brand longivity. Mike
Old Feb 8, 2001 | 10:16 PM
letitsnow's Avatar
Thanks for the advice.
Alex G.
Sep 19, 2015 06:34 PM
nastyblaster100
Sep 13, 2015 01:19 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
black798
Sep 9, 2015 07:42 AM
