giovanni 110cc atv
Old Oct 6, 2008 | 06:54 AM
gre1400's Avatar
Default giovanni 110cc atv
I just bought my nephew one of these and I was wondering if there is anything I should know about. I was doing some reading on here and it says i should change the all the fluids once i receive it, is that correct? if so do you know what kind of fluid I will need? Also is this atv reliable? was this a good purchase? I havent received the atv yet it should be here on thursday I just want to try and get a head start. Thanks for your help.
Old Oct 7, 2008 | 08:39 PM
gre1400's Avatar
anybody??
Old Oct 8, 2008 | 10:39 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum gre1400! [img]i/expressions/face-icon-small-smile.gif[/img]
Basic Chinese ATV setup... loctite darn near everything. Especially ALL the fasteners that hold on plastic and little brackets. If you use a screwdriver or a 8 or 10 mm wrench on the bolt/nut...loctite it. Use the blue version. I would change the oil before even starting the engine. Id use Valvoline 10wt-40 and change it after about 5-10 hrs of run time. Your also going to want to check a few adjustments... does the quad steer straight? might need tie rods adjusted. Do the brakes work? Might need to adjust them.
Chinese ATV's are generally more reliable based on the amount of time dedicated to setup.(but not always true) You need to remember that when you buy a atv in a crate you save a lot of money.... but you become the dealer. d
Bratman2
Aug 6, 2022 01:42 AM
wrencher82
Sep 28, 2015 10:02 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
Waddell4436
Jul 20, 2015 09:46 AM
