Carb help
Old Oct 10, 2008 | 02:25 AM
spoolnaround's Avatar
Default Carb help
I replaced the valve piston in the carb and now it floods really bad. I have an exhaust leak at the cylinder/pipe flange and this thing floods so bad raw fuel is dripping out of the flange. Did I put the carb back together wrong?? I have changed out the needle and seat and it still leaks, what could it be?
Old Oct 10, 2008 | 02:26 AM
Default Carb help
Oh ya its a 92 Lt 80
Old Oct 10, 2008 | 05:27 AM
Monkeyfish's Avatar
Default Carb help
I'd make sure you have the throttle slide in the carb the right way round as the top will screw on these with it in wrong. The side with the groove running right down faces the choke. Also check it can slide up and down easily.
You could check the float is moving freely and the float height is correct too.
Old Oct 10, 2008 | 09:52 AM
LT80's Avatar
LT80 Expert
Default Carb help
There is no float adjustment.
Did you remove the seat and clean?
OK, this happens. The fault can be debated but the answer is a on/off valve from a lawn mowershop/autozone for around 3-4 bucks.
Old Oct 10, 2008 | 10:49 AM
Default Carb help
Lt, are you sayng replace the petcock?
Old Oct 10, 2008 | 10:58 PM
LT80's Avatar
LT80 Expert
Default Carb help
You can. But the stock replacement costs alot. A banshee petcock works.
What I'm refering to is a simple on/off valve. You twist it on to run and when done you twist it to shut the fuel off. It goes between tha petcock and the carb.
A inline fuelfilter is also good idea. I see this stuff at the auto zone and is like 3 bucks each.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
