700 EFI Diagnostic troubleshooting
Old Oct 10, 2008 | 10:07 PM
GoingVirtical's Avatar
Default 700 EFI Diagnostic troubleshooting
Tech question,
I have an 05 - 700 EFI. My "check engine" stays on continiously. I did a diagnostic check and codes 45, 46, 41 come up. The book tells what each problem is.
This may have been self inflicted. My battery was low and I had to jump it. Once it started I went to remove the positive and it slipped and grounded to the frame for a nano second. This was a year ago and I'm starting to experiance trouble when it's running.
Q-1.....Here is my question.......Is this plug and play parts or do I need to take it to a dealer to have it reset?
Q-2........I have a had continous issue with my coil. I'm always missing a cylinder and have had to replace the plug wire 3 times. I ran a ground strap to hopfully help with this. It more prvelant when wet. I had noticed they have replaced the part number with another. Have any of you experianced this
Any help or suggestions you may have will be apprciated.
Old Oct 11, 2008 | 05:44 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
grounding has been an issue for some so another ground w/ dielectric grease wouldnt hurt. unhook the battery for a little while then rehook to erase the codes to see if they come back. check the battery for voltage as well to see what it has off and w/ the bike running reved up to see if the out pt is right. just an idear.
Old Oct 12, 2008 | 01:22 AM
Easy enough, I should have thought about diconnecting the battery but I over looked the obivious. This is a good start, Thanks for the tip. I did use diolectic grease and completly disasembled the coil and shined the meatal up before reinstall. I stopped at the dealer and conveyed my issues, he had a dumb stare and said to bring it in. Agian thanks for the tip.
PS. they had a new 850 on the floor, pretty cool but at 8500 I'll keep mine.
Old Oct 12, 2008 | 08:59 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
let us know.
pgamboa
Dec 24, 2023 11:52 AM
speedbuff
13
Nov 11, 2020 10:16 AM
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
Sw00p
Sep 24, 2015 02:50 PM
