99 500 rse problem
Old Oct 11, 2008 | 02:33 PM
dave.570's Avatar
Default 99 500 rse problem
last year i changed the cam on my 500 sportsman. had troubles getting it to run was popping back through the intake. finally got it to run. i was riding and it just died. after replacing needle jet, jet needle, needle valve, and diaphragm assembly. now it runs but blows gas back into the air filter and i don't know why. i checked the timing and it seems fine. thanks for any help.
Old Oct 11, 2008 | 03:33 PM
Check valve clearance for tight valves, Timing MUST line up with cam sprocket locating pin center of head,plus index mark on crank sprocket must line up on case mark.If carb correct as you say,ONLY thing I can think of.Plus if piston worn can also cause problems.Did you pull head and check piston/ring wear also?
Old Oct 11, 2008 | 05:08 PM
dave.570's Avatar
i did not pull the head. compression was about 90 psi. wot lacks power also.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
