New to riding and i need some help
Old Oct 14, 2008 | 07:22 PM
atvchic022's Avatar
Default New to riding and i need some help
I just bought a 2000 trailblazer and went out last weekend for the first time. Im having a problem with the machine. It runs great intill it starts to get hot, after alittle while riding it starts to get slugish. We thought it might be a problem with the belt but after checking it out it looks brand new. the spark plugs are brand new. The machine is basically brand new. I bought it off a guy at work who says they only went out riding on it a few times. I have a 4 stroke bike yamaha 250 TTR but I dont know much about 2-strokes and this is my first atv. If anyone could help me out on what i should be looking for id appreciate it
Old Oct 14, 2008 | 09:38 PM
Sidewinder500's Avatar
give it a compression test you should be around 120 psi for best performance anything below 80 and its time for a top end rebuild
Old Oct 14, 2008 | 11:50 PM
eggenz7's Avatar
anything below 100 its time for a rebuild. check for air leaks. since it has an aluminum crank case and it seems to be heat related, the crankcase may expand somewhere and allow air into the cylinder. 2 strokes need to be air tight to run correctly because of their nature. a normal failure spot are the seals on the crank shaft. very easy to replace.
Old Oct 15, 2008 | 12:07 AM
atvchic022's Avatar
Thanks alot...
Nondem
Feb 22, 2020 12:20 PM
HondaR24
Jul 16, 2015 10:45 AM
honda71
Jul 12, 2015 05:56 AM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
honda71
Jul 8, 2015 02:13 AM
