08 Rancher rear shock
Old Oct 18, 2008 | 02:51 PM
mjrcpd's Avatar
Default 08 Rancher rear shock
Hey all. I've got a 08 Rancher 420 ES 4wd and quite honestly, I'm disappointed in the rear shock. The shock isn't adjustable and has no pre-load settings, and unfortunately, I'd like the rear end more stiff. Do I need to swap out the shock for a clicker? Is this recommended? Other than length, what other considerations do I need to be aware of? THANK YOU for your thoughts.
Old Oct 18, 2008 | 07:40 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Wow, you are probably the only person on earth that thinks the Rancher shock is to soft! Try WorksPerformance.....
Old Oct 18, 2008 | 10:29 PM
mjrcpd's Avatar
I doubt I'm alone! Thanks for the info.
Old Oct 18, 2008 | 10:50 PM
sac7000's Avatar
I tried using a rubber wedge in the rear monoshock spring on my 07 Rancher but what I'd really like to do is soften up the front shocks and leave the rear alone.
Old Oct 20, 2008 | 05:58 PM
tramp's Avatar
Hi-Lifter carry's an overload spring for the 420. They will raise it up about an inch. I put them on the front and rear. They increase the load capacity buy a 100lbs. I put them on the front cause my snowplow was sagging the front so bad and on the back cause I was carrying a passenager alot. However after I got my wife her own 420, I put the stock spring back on the rear cause of the hard ride, still have them on the front however. Check Hi-Lifter, they carry the complete set plus the spring tool as a set, or you can buy only the front or rear. However you will need the tool to change them.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
Dammar
Aug 26, 2015 07:12 PM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
