hay ride on hollewen night
Old Oct 18, 2008 | 10:32 PM
rhonda350's Avatar
Default hay ride on hollewen night
I bought a 5x8 carry on trailer mesh floor with a gate so I can haul around my atv. The thing I dont like about it that it flexs to much. I step on one side in the front and it would lean and im 200lbs. Should I do the hay ride or not. There is going to be atleast 6-10 people on it. Plus im going to finsh the trailer of with wooden planks. I currently have two planks of 8ft long 1ft wide and a inch thick for where the tires of the atv go if u know what i mean.
By the way how would i do the hay ride just throw some hay bails on the trailer and they sit on that or what give me some ideas. This is my first time doing a hay ride.
Old Oct 19, 2008 | 10:47 AM
eggenz7's Avatar
once you put the wood in there and screw it down it will take a lot of the flex out of it
Old Oct 19, 2008 | 11:12 AM
700 sportsman's Avatar
I think you ought to be just fine
Old Oct 19, 2008 | 12:10 PM
Outof$'s Avatar
Most of those type trailers are rated by axel wieght. I believe yours should be rated at 3000 lbs. So if you stay close to that with the wood, hay and passengers you should be fine.
Old Oct 19, 2008 | 08:02 PM
snorulz's Avatar
don't forget to figure in the weight of the trailer when calculating how much weight is on the axle.
Nondem
Feb 22, 2020 12:20 PM
honda71
Jul 12, 2015 05:56 AM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
honda71
Jul 8, 2015 02:13 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
