2002 Lakota Sport HELP!!!
Old Oct 20, 2008 | 07:43 PM
drewman09's Avatar
Default 2002 Lakota Sport HELP!!!
I went a away for a few months and havent touched my machine. Was working great when I left but now cant get it started. PLease help!
Old Oct 22, 2008 | 12:40 AM
Vunit's Avatar
Need more information, whats it doing excatly...carb could be gummed up, battery could be dead...there could be many of issues...not making it sound like you dont know what your talking about just need more information...then we can take it step by step...
Old Oct 27, 2008 | 11:33 PM
jeffeosso's Avatar
gas? fire? electrical?
if your battery is dead, a new plug nearly always helps when using the recoil starter, got gas?
Old Nov 14, 2008 | 06:35 PM
drewman09's Avatar
In truth I really do not know that much this is my first machine and I have only had it for a year or so.
well i recharged my battery, replaced the spark plug and filled the gas tank and it started and ran fine however when I tried starting it again a week and a half later it started but would not idle.
When I replaced my spark plug there was not much carbon on it but there was fuel on it is it possible that it is running to rich?
Old Nov 15, 2008 | 08:39 AM
jeffeosso's Avatar
did you get a second plug?
your fuel is probably ruined OR the carb is gummed up and needs to be cleaned out
dang, man, i love my lakotas, sorry to hear yours is hung up
Old Nov 16, 2008 | 01:55 PM
drewman09's Avatar
yea and when I put the new plug in it stated just fine. The fuel is fine I just put it in though I did put fuel stabilizer would that effect it at all?
If the carb is gummed up how would I go about cleaning it?
Old Nov 16, 2008 | 05:57 PM
jeffeosso's Avatar
i would either run that tank dry or drain it and refuel.
Old Nov 16, 2008 | 06:51 PM
drewman09's Avatar
well i cant get it started so I cant run the tank dry and if I changed the fuel why would that change anything if the carb is gummed up?
Old Nov 16, 2008 | 07:08 PM
jeffeosso's Avatar
drain the tank, and put some new fuel in it.. but, if you don't know how to rebuild/clean one, you should be able to find a local guy that can clean it it.. that's probably all it is, bad fual, some what dirty/gummed up carb, and that's all...
fuel is easy enough.. if you get a long piece of fuel line tubing, you can drain into an empty gas can..
I hope it's not messed up fuel lines.. a friend says that seafoam messed up his fuel lines... it worked okay for me, but i don't think i'll use anything buy stabil.
when i tried it to clean out my carb (deep creep), it was very difficult to keep running, and it died and was tough to get restarted.
drain the fuel.. or, if it's mostly out, refil with super unleaded
taking it off isn't hard, at all..
if you can't get it done, find a local guy to rebuild it
95wolv
Sep 27, 2024 12:00 PM
Sep 30, 2015 01:37 AM
cboler9
Sep 24, 2015 08:35 PM
byronman
Sep 6, 2015 06:34 PM
