2005 Sportsman 90cc
Hey Guys,
Just recently purchased my son an 05 Sportsman 90. The rear brakes are in need of new shoes and I was wondering if any special tools to get the drums apart are required. We have only had Hondas and on those you just remove the wheel and pull the drum cover off.
Also,
It did not come with an owners manual so I need to figure out how to change the Transmission fluid (amount and weight).
Bikes seems to be pretty solid and we love the reverse feature.
Thanks again!
Also,
Thanks again!
Just remove drum,shoes easy to replace. Small drain plug under neath for gearcase. fill plug should have diptsick mark,Use AGL trans fluid,even though most of the ones I've changed have a thicker fluid from the factory.
