84 200S that's working great
Old Oct 22, 2008 | 12:00 PM
rjdad's Avatar
Default 84 200S that's working great
I have a 84 200S that runs great. When I change the oil it comes out black and I was wondering if there is some type of flush that I can use that will remove the excess carbon and not damage the clutch system. Thanks as always.
Old Oct 22, 2008 | 06:10 PM
2XVision's Avatar
While it`s true some trash builds up in the crankcase due to clutch wear and etc. I`ve found it in several I`ve torn down. I would drain some oil out maybe a quarter way down, pour in some seafoam to the full mark. Then ride but not hard for about 15 minutes. Then change the oil. You`ll be surprised how black the oil is that comes out, also make sure you tilt it and let it drain at least 30 minutes. On the refill I recommend pure synthetic oil. As in most cases using regular conventional oil after as little as 2 hours of riding it`ll already be black. After switching to synthetic I can get 10 to 12 hours before the oil goes black.
Old Oct 25, 2008 | 12:51 AM
SMFREY's Avatar
I am not so sure putting synthetic oil in an older engine with automatic clutch would a good move
On these engines I have found the Honda Gen 4 oil works great
I run in all my bikes
What I did was simply change oil a couple times after each weekend riding
Now when I change oil it comes out clean
Just my opinion
Stay Safe
Ray
VRRRRT
Jun 27, 2015 09:38 AM
mikerublee
Jun 25, 2015 09:31 PM
WilliamBos
Jun 11, 2015 05:57 PM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
