500 scrambler clutch question
my question is on my scrambler my clutches are 10 1/2 inch apart are they supposed to be this far apart and my clutch does not grab well.it has new belt and i would like to get it to pull better any help greatly appreciatted thanks
Supposed to be 10 inches center to center of clutch bolts. If off,check front motor mount for damage/movement and engine in general for movement. Also clutch alignment,plus rear clutch parts wear can cause problems.
<div class="FTQUOTE"><begin quote>Originally posted by: dago-fast
I had a similar problem on my scrambler. I got a clutch kit from erlandson performance inc. Now it snaps the back tires loose on pavement. well worth it.</end quote></div>
A Lot better clutching for less $$$$$$ than EPI.But if it works..................
