angle sensor
Old Oct 24, 2008 | 09:07 PM
trailmaster500's Avatar
Default angle sensor
HAVE A PROBLEM WITH ELECTRIC SHIFTER ANGLE SWITCH PROBLEM HOW DO I CORRECT THE PROBLEM AND WHERE IS IT LOCATED tHANKS
Old Oct 25, 2008 | 04:12 AM
zitaron's Avatar
which atv?? model and year?? symptoms??
Old Oct 25, 2008 | 09:36 AM
04 rancher with electric shift where is this located
Old Oct 25, 2008 | 12:53 PM
zitaron's Avatar
Angle sensor is on front of engine casing - facing forwards behind a metal cover with two 10mm bolts that hold it. you can disconnect the battery , switch off the petrol , and put it up on the back rack. then when you look in over the bash plate it is straight in front of you.
if you change it out, make sure you replace the rubber 'o' ring -- and keep everything clean.
Old Oct 25, 2008 | 05:09 PM
HondaMechanic's Avatar
Old Oct 26, 2008 | 09:38 AM
All set Thanks for all the help again you guys are great again thanks
Jeff Roper
Feb 1, 2022 11:48 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
60
Dec 14, 2019 06:13 PM
Jeff Roper
Sep 21, 2015 02:11 PM
