wheel spacers,,dumb question
Old Oct 25, 2008 | 08:12 PM
HARLEY_OWNER's Avatar
Default wheel spacers,,dumb question
what exactly are they... do they just make wheels stick out like a mexican low rider or what??
Old Oct 25, 2008 | 08:28 PM
Kinda sorta! Also allows room for wider tires to keep from rubbing against tierod ends,etc!
Old Oct 25, 2008 | 09:41 PM
firehog's Avatar
Most people add them to allow clearance of the tie rod ends. Others add them for a wider stance and more stability. I add them on most of my atv's and utv's as they aren't as tipsy. They have nothing to do with a mexican lowrider, but that theory makes me laugh! Just add some fuzzy dice to the handlebars! Maybe some ape hangers, too! LOL!
Old Oct 25, 2008 | 09:54 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
dont forget the air supension fire to drop it to the ground to drag for the sparks.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 25, 2008 | 11:53 PM
upnort's Avatar
Sten you might be on to something there but in reverse. When you are hi centered press a button to get the air suspention to raise you up for more clearance, get that frame up off the hump.
Old Oct 25, 2008 | 11:57 PM
lol no thats sum ****.. upnort where you from.. wisconsin? its supose to snow tomarrow night... and i still need to get a plow...
and by the way that wheel spacers is prolly somthing i need.. i found a place to get a 2 inch lift kit and i wanna get some 27 inch tri-claw tires before next spring
Old Oct 26, 2008 | 09:43 AM
700 sportsman's Avatar
I would get offset rims versus the wheel spaces
Old Oct 26, 2008 | 11:45 AM
why would get offset and not spacers... is there a down fall or some kind of wear?
Old Oct 26, 2008 | 12:15 PM
eggenz7's Avatar
its a little bit stronger. there are two types of wheel spacers one you remove the original studs and place long studs in (usually about 1" longer than what the spacer is) then the spacer slides over those studs to keep the rim off the hub.(the weakest one) or there is one that you take the studs out of the hub and the spacers has studs made into it that you bolt to the hub and there are another set of studs for the wheel on the opposite sides. a little stronger but getting offset wheels is the strongest way. the wheel spacers are the cheap way out.
Old Oct 26, 2008 | 03:49 PM
user493's Avatar
Moto Psycho
If I ever bought wheel spacers I would only get some like this. http://www.drivenproductsinc.com/ATVproducts.html
