wheel spacers,,dumb question
<div class="FTQUOTE"><begin quote>Originally posted by: HARLEY_OWNER
why would get offset and not spacers... is there a down fall or some kind of wear?</end quote></div>
Wheel spacers are harder on parts. Wheel bearings,ball joints ect. Think about the leverage they create. I couldn't believe it when I read people using 1 1/2" spacers..wow.
Offset wheels are better.
<div class="FTQUOTE"><begin quote>Originally posted by: HIGHOCTANE
Offset wheels are better.</end quote></div>
If your wheels or spacers move the tires out they're still out there. Don't offset wheels create the same problems because of the extra leverage they create? I heard that they do a lot off damage to cars with extreme offsets. That's the ones I refer to as Hot Wheels cars. They look more like toys than serious cars.
#15
Yes they cause issues if the offset is extreme also,but IMO the mechanics is different with an offset wheel IMO. I don't think 1" change in offset is as significant of a load change as a 1" spacer. I'm not and engineer,I could be wrong. That's just how I see it.
#17
<div class="FTQUOTE"><begin quote>Originally posted by: upnort
I would think 1" is 1" no matter how is done. Length x force whether it is a bolted on spacer or offset rim.</end quote></div>
You're probably right, I think I might be over thinking it. I was just thinking that unless the offset is extreme that the design of an offset wheel causes the load to be in a vertical plane,and that load is place at the hub. Wheras the spacer moves the load father hub and thus from the ball joints creating leverage.
#19
#20
<div class="FTQUOTE"><begin quote>Originally posted by: jumbofrank
If I ever bought wheel spacers I would only get some like this. http://www.drivenproductsinc.com/ATVproducts.html</end quote></div>
3" is WAY too much. All you more than likely need is a 1" spacer.
If you go that wide, you will put extra stress/wear on all components BIG TIME!
And good luck making it through the tight trails.
