mojave knocking
Old Oct 29, 2008 | 11:03 PM
smitty800's Avatar
Default mojave knocking
i have a 04 mojave and the engine is knocking it seems. i had o4 motor and it did the same but the transmission went out before i could fix it. now i got a o1 motor and carb and ive been riding it and it sounded fine and then all of a sudden it started knocking like the last motor i had. any ideas?
Old Oct 30, 2008 | 03:56 AM
skj283's Avatar
you think it could possibly be a tranny problem? sometimes with everything being so close it is hard to tell. with the other having a catastrophic transmission failure shortly after it began knocking, i think i would look there first.
Old Oct 30, 2008 | 08:28 PM
smitty800's Avatar
yea but i had someone look at it before the transmission went out and they all said it was coming from the top end. and i tried the trick were you put like a pole up to the motor and listen to it to see where the noise was and the bottom end sounded good but the top end you could hear it
Old Nov 1, 2008 | 04:26 PM
skj283's Avatar
is it a really fast knock or kinda a tick tick tick when its idling? could be a rocker arm and it would sound slower than a rod cuz it only occurs every other rev instead of every one like a rod.
Old Nov 1, 2008 | 05:38 PM
smitty800's Avatar
i noticed today that it does it mostly right when i start it up then it goes away. its not a real fast knock. i have the other motor valve cover off what can i look for on it to see if what your thinking might be the proble because the other motor did the same thing but it did it all the time when it idled. also i herd it could be the gas you use? should i use premium
Old Nov 3, 2008 | 03:28 PM
skj283's Avatar
i dont imagine it is detonation. i would say you have a rocker a little loose and it is swelling up once it gets some heat in the motor. i would check the valve clearance first.
Old Nov 3, 2008 | 07:27 PM
mojo21's Avatar
Mine knocked like that when you reved it...specially bogging it in a low gear or pulling out. You could ask anyone on here that knows mojaves, they know they knock. No one knows exactly why they do it ....mine i rebuilt a zillion times and had everything in specs and still knocked. Simple solution to the annoying noise....get a pipe!! i put my pipe on and you cant hear the knock!
Old Nov 3, 2008 | 08:56 PM
smitty800's Avatar
well its not as bad as it was but i still would like to adjust the valves b4 i put my knew maier plastics on and the other stuff im bout to get for it. how do i adjust the valves? what tools do i need. im only 15 but im pretty good at workn on them i just dont know a whole lot bout what stuff is like i lookd in another fourm on how to do it and i didnt know where the stuff they were talkn bout was. also i have one other issue on my mojave if i kick the kick starter sometimes it kinda slips but then graps again. would that be the kickstarter shaft gear or the one it turns you think?
Old Nov 7, 2008 | 03:06 PM
skj283's Avatar
generally if a motor is gonna detonate it is gonna do it under a heavy load i.e. just after letting out the clutch or lugging it around, idling they usually dont unless you have issues, i would say they have too much ignition timing in them if they are that prone to detonating.
Old Nov 8, 2008 | 01:28 PM
mojo21's Avatar
to adjust the valves you need to take the valve cover off of your head. Its 6 bolts then you will need a feeler guage to use in between the rocker arm and the valve stems. Onnce you have that cover off you will see what im talking about...theres 2 little adjusting screws on each rocker arm you will need to adjust. A flat head screw driver and a 10 mm wrench you will need to do this. Im not possitive on the stock specs for what they need to be adjusted ill look in the book and post them asap!!! hope this helps hit me up if you need more help
Kenny
01ssls1
Sep 22, 2015 06:50 AM
merryman
Sep 19, 2015 03:15 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
