warrior
Old Oct 31, 2008 | 12:46 AM
Andrew's Avatar
Default warrior
it has good spark and I just rebuilt the carb if the air screw mixer is not right will it not run and if so what is it set to I set it to 1.5 2 turns
Old Oct 31, 2008 | 01:06 AM
beefy46172's Avatar
Loves To Ride!
Default warrior
Its a fuel screw, but yes that is close to factory spec and it should at least run. Getting good compression and fuel flow to the cylinder? Valves adjusted properly?
Old Oct 31, 2008 | 10:19 AM
Andrew's Avatar
Default warrior
no its the air screw. if the valves were off would it not run. it run befor i rebuilt the carb but it would pop and die. I just dont know what it is? I just got a new coil
Old Oct 31, 2008 | 11:38 AM
beefy46172's Avatar
Loves To Ride!
Default warrior
It very well will still run if the valves are off, just maybe not good. I just posted directions in this thread on how to adjust http://forums.atvconnection.co...tid/13/threadid/553815
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
