02 P650 Winch mounting Q's
Old Oct 31, 2008 | 09:41 AM
mxz71's Avatar
Default 02 P650 Winch mounting Q's
I just installed an Xtreme winch on my 02 P650. Does anyone have any slick Ideas on a mounting position for the handlebar switch? The Stock Levers & Controls take up alot of space on the Left bar. I ended up doing a vertical mount and It will work but its not as clean as I'd like. Any Ideas? ALSO where would be the best location to mount the contactor.... I'm planing on mounting it under the seat but the one on my 05 Cat is right next to the winch exposed.
Old Oct 31, 2008 | 12:49 PM
Hayashi's Avatar
There is not much space on the left side handlebar area but my Warn (2500) winch's switch barely fit on there.
I mounted the contactor in the very rear of the ATV under and tail light area on the tube frame.
I will try taking some photos and show you.
Old Nov 1, 2008 | 01:26 AM
OGGYDOGGY's Avatar
I mounted mine in the box under the seat.
Old Nov 1, 2008 | 08:58 AM
mxz71's Avatar
Well.... I did get the contactor mounted..... Switch Mounted..... And wouldn't you know it.... The contactor was bad right out of the box.... It will reel out my cable...But not reel it back in.... I am getting a squeal from the contactor when you push the button to reel the cable in.... Everything is wired correctly... So I had to cheat and use a battery directly to my Winch motor to reel the cable in....
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
