women warriors and clutches
I ride a warrior and I have a real hard time reaching the clutch. I am a girl with small hands to boot. Any one have any suggestions? Any one out there had same problem and tried to bend the clutch? I tried one off a blaster, I could reach it but then it was shorter and too hard to pull. HELP!!
Stock clutch lever is pretty easy to bend (did it a dozen times before I switched it
) Dont know of any clutches that would ride closer to the bar though. Seems to me that if you simply bent your stock lever you wouldnt get enough cable movement to properly dis/engage the clutch. Do you have a problem with the front brake as well?
