Choke Cable on Rancher
Old Nov 9, 2008 | 08:27 PM
saby5757's Avatar
Default Choke Cable on Rancher
I have a question concerning my uncles 03 Rancher...
For some reason, we can not pull out the choke cable..... it is stuck and won't pull out..
What should I check for or how do you suggest loosening it?
Thanks
Old Nov 9, 2008 | 08:59 PM
Y2daT's Avatar
I would remove the seat and fuel tank then try to remove the chocke from the carb to see if its stuck there .(its at the other end of the cable)..if not then its prob the cable replace it or try to use a solvent like pb blaster to free the cable ...
Old Nov 10, 2008 | 01:56 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Water get into the cable between the cable and housing and rusts it. Lube it, or better yet just replace the whole thing.
Old Nov 10, 2008 | 11:47 AM
zitaron's Avatar
Carefully unscrew the cable from the carb. Remember that the cable and the end piece are 2 separate things. Free out the part going into carb - clean it very lightly with fine sandpaper- lube everything. if your cable will freely pull up the end enrichment screw, and the screw looks good, simply re-assemble (getting the thread back on can be tricky -don't force the thread).
But if is still stuck - replace the cable. should do it.
Johnny Mac
Aug 15, 2019 03:13 PM
wrencher82
Sep 30, 2015 04:27 AM
2many2ride
Sep 27, 2015 04:35 AM
Clint Russell
Sep 25, 2015 03:20 PM
wrencher82
Sep 24, 2015 03:39 PM
