06 Rancher 400at Not shifting correctly
Old Nov 14, 2008 | 06:32 PM
jdstiles18's Avatar
Default 06 Rancher 400at Not shifting correctly
I just purchased this 06 Rancher 400at with known shifting problems. It was flashing esp 12 times and stuck in first.. I found that the 30A fuse to the shift motor had blown. Replaced the fuse and it has found itself to a higher gear but displays 1st on the screen.. Now flashing code 5.. I took the shift motor off and spun the gear linked to the shift motor counter clockwise until it stopped.. Is it supposed to stop or can it be the angle sensor thats got this thing out of whack. Any Suggestions?? Thanks
Old Nov 14, 2008 | 10:04 PM
HondaMechanic's Avatar
Code #5 is an angle sensor code ..
Old Nov 15, 2008 | 04:07 AM
jdstiles18's Avatar
OK thanks for the information.. The shift motor checked good. However the shaft joint still gets stuck when turned all the way counter clockwise.. Went ahead and checked the resistance of the angle sensor to the ECM.. Reading for that was .79 ohms which is below the normal 1.6.. Im going to get another angle sensor to put on it but what I still need to know I guess is if the shaft joint is supposed to stop when turned all the way counter clockwise or could it be sticking because the angle sensor is checking bad.. Thanks
Old Nov 15, 2008 | 07:33 AM
Don't forget to preload the new angle sensor when you install it...
Old Nov 15, 2008 | 08:15 PM
jdstiles18's Avatar
Ok got the new angle sensor today.. Put it in and evertything works just as it should.. Thanks so much.. I reset the 5 blink code but is it still necessary to iniatilize it even though everything is working normally..
Old Nov 15, 2008 | 11:03 PM
The ECM should be initialized even if you don't initialize the speedometer ..
At least this part should be done..
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
2many2ride
Sep 27, 2015 04:35 AM
Clint Russell
Sep 25, 2015 03:20 PM
Elkaholic
Sep 6, 2015 02:44 PM
