Continued Problem
I have had some good response and I found a burnt wire that went to my coolant switch and so I replaced it. I still get a light on when even with no key in the keyswitch or even when nothing is turned on but with the key switch on and in run position the coolant light goes out. Can there be a problem in my rectifier.
Depending on the year..........You may have a bad "Sure Power Control Module"...(Black Box).......There was a recall on some years.............Just to let you know..........Caper.............
