Antifreeze leak
Old Nov 18, 2008 | 01:56 PM
johnnyb1997's Avatar
Default Antifreeze leak
I have 1997 Polaris 500 sportsman. Some of the time antifreeze will bubble back through the antifreeze holding tank on the side of the engine. What will cause this?
Old Nov 18, 2008 | 02:04 PM
Koerbs's Avatar
When does it do this? when its running for a few minutes or all the time?
Old Nov 18, 2008 | 03:04 PM
When you shut it off and it sets for a while. I am going to replace both of the hoses from the radiator back to the block.
Old Nov 20, 2008 | 06:33 PM
gaugedholes's Avatar
hey jonny let me know my 96 sp500 does the same thing...
Old Nov 20, 2008 | 06:40 PM
SCRAMMYTODD's Avatar
The tank is an overflow. When the engine gets hot the antifreeze will expand and flow to the overflow. When it cools it will draw the coolant back into the rad. If your rad is a little low or has some air in it you may see some bubbles in the overflow. Take the rad cap off and make sure your coolant is all the way to the top of the rad.
Old Nov 20, 2008 | 06:44 PM
thakns bro...i'll try that
Old Nov 21, 2008 | 09:51 AM
What can we do to correct this problem? Mine just started this.
Old Nov 21, 2008 | 10:08 AM
MECHANIKE's Avatar
there is an air valve + a vacuum valve in the rad. cap. if its dirty or out of value it will be uneven when opening to dispence the expanded liquid into overflow.it won't be even,slow and smooth,you should barely if at all be able to notice it.it will be in surges.
Old Nov 21, 2008 | 10:56 AM
ZAKAZIM's Avatar
I had this same issue on a 2000 500 and I did everything I could think of with no luck. Then Just blowing off changing the cap thinkin it could not cause this, I was wrong. I P/U a cap at napa I think it was a 13lb cap. I could see just looking at them this was it so after toped it off I ran it with the cap off untill all the air was out and put it on and all was good.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
