Front diff bearing install
Old Nov 20, 2008 | 01:07 AM
Rattlerock's Avatar
Default Front diff bearing install
Hello I just joined tonight.
I have a sportsman 700 its a 02 model that I bought used I am in need of a schematic or manual. My local dealer is out and has one on order for me. I was really wanting to get these bearings installed on the front diff. I am very much capable on the mechanical side, I have restored several harleys from the ground up. I have never worked on a ATV and I am wondering if there is a good diagram anywhere on the net. I may tackle this without one but like to have it just in case. I am also looking for new front and rear fenders or ones that are in good condition. I have heard that the 500 sportsman fits the 700. Any good sources other than the dealer?
Thanks in advance
Old Nov 20, 2008 | 03:04 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome. most of the same generation body parts will fit as thier pretty much the same except for engine and a few other small things. theres a site(as always cant remember) that actually sells take off parts that makes products out of the drive train parts. maybe someone here will remember the site. also might be able to down load you a pdf manual for that year.
Old Nov 20, 2008 | 05:09 AM
Rattlerock's Avatar
I would love to know the name of that site. I have a half azz diagram off of Polaris's site.
Old Nov 20, 2008 | 08:54 AM
sheepdogMSP8117's Avatar
Is this what you mean by schematic? I got it from bikebandit.com Hope it helps.
Old Nov 20, 2008 | 08:55 AM
Sorry, #9 is the bearing.
Old Nov 20, 2008 | 10:02 AM
teamplayer's Avatar
I have a set of black fenders (front and back) from an 02. PM me if you are interested.
Old Nov 20, 2008 | 04:15 PM
Rattlerock's Avatar
You have a PM
Old Nov 20, 2008 | 04:16 PM
Rattlerock's Avatar
Thanks Sheepdog thats a better view than the 2"x2" one that I got off the net
Old Nov 20, 2008 | 09:25 PM
lksyotas's Avatar
Hello Rattlerock,
Just be sure that you press on the inner race of the bearing when you are reinstalling the new one. Mount the gear or hub that that bearing gets pressed onto on a solid flat surface (preferably a arbor press) so you can provide even pressure while seating the bearing. Do not hammer the bearing on or again, premature wear may occur. PM me if you need any assistance on reassembling the front drive properly. I helped design it. Regards,
Old Nov 20, 2008 | 11:04 PM
Rattlerock's Avatar
It ends up that it was not the bearings as thought. Its a ball joint, inner axle spline and inner axles sleeves .................nice surprise! If you like spending money
Ean
Dec 19, 2022 08:48 AM
JackTheKing
Jul 14, 2015 09:09 PM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
