Predator 500 issues
Old Nov 20, 2008 | 03:41 PM
linko013's Avatar
Default Predator 500 issues
Hey guys, I got my predator about 7 months ago. I traded my bike plus cash for it. Supposeably its bored,ported. I know its jetted bc Ive changed the jets a few times and it also has a yosh full exhasut system. Ive been having a lot of problems with it. My main problem though is it starting. This thing runs through batteries. It does this weird clicking noise every time I hit the start button and itll take a lot of clicks until it finally starts. Lately though, it wont start at all unless i jump it. Itll just keep clicking and clicking. What would be causing this? Is the starter shot? I cleaned off all of the starter relays and solenoids etc. every electrical part running to the battery. Anyone know what is causing this and what my fix is? There is also this 12v regulator that runs off the battery, its a small square box thats connected to 2 different wires that are running to the battery. I wasnt sure if that could be bad or if it even belongs on there.
Old Nov 20, 2008 | 04:32 PM
Groovy's Avatar
Have you checked the voltage at the starter? Almost sounds like it is undervoltage.
Old Nov 20, 2008 | 04:34 PM
linko013's Avatar
No I didnt check.. What would be causing that though...
Old Nov 20, 2008 | 04:36 PM
Groovy's Avatar
a run down battery
Old Nov 20, 2008 | 04:37 PM
Rattlerock's Avatar
Turn the key on and have someone tap the starter with the wooden end of a hammer if it starts easier your starter is going south. If not check all wiring for loose connections and cut insulation. Voltage is a weird thing. Remember to look at it like water it is going to take the path of least resistance. An nick in a wire can cause some crazy results. My money is on the starter though.
Old Nov 20, 2008 | 04:39 PM
linko013's Avatar
Ive gotten 3 new batteries since i had it... If not more.. Get this, one time i was out just got done ridin it hard. Turned it off to take a brake, went to start it back up .. Click click click n then boom. The battery that was first in it exploded.. It was one of those gel batteries. The battery that I have in it now i just got less than a month ago
Old Nov 20, 2008 | 04:49 PM
Groovy's Avatar
wow... thats gotta suck. If you are going through batteries I would check to see if your charging unit is working as intended.
Old Nov 20, 2008 | 05:10 PM
700 sportsman's Avatar
I would take off the starter solenoid and take it to the local parts store and have it tested, the starter solenoid is what you here click, I would guess its about ready to crap out
Old Nov 20, 2008 | 05:59 PM
firehog's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 700 sportsman
I would take off the starter solenoid and take it to the local parts store and have it tested, the starter solenoid is what you here click, I would guess its about ready to crap out</end quote></div>
I agree. I have had two preddys and never had a problem with them starting or going through batteries. Generally, sportys don't eat batteries like a ute. Problem has to be the starter and/or solenoid.
Old Nov 20, 2008 | 08:05 PM
linko013's Avatar
Ill just buy a new solenoid then off of ebay i think.. Should I get a starter for the hell of it too or?
