Predator 500 issues
Old Nov 28, 2008 | 11:12 AM
  #31
linko013's Avatar
Default Predator 500 issues
Anyone have or know anyone who has a rear predator 500 rim? I need to buy one but I dont wanna spend 150.00 for one from a dealer... I cant find any cheap anywhere else.. Its hard to find rims that are 10 " for a racer. Even if anyone has a cheap set of tires and rear rims that are 9 ". I can drill out the bolt pattern myself..
Old Nov 28, 2008 | 01:31 PM
  #32
Evasiveone's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: linko013
Anyone have or know anyone who has a rear predator 500 rim? I need to buy one but I dont wanna spend 150.00 for one from a dealer... I cant find any cheap anywhere else.. Its hard to find rims that are 10 " for a racer. Even if anyone has a cheap set of tires and rear rims that are 9 ". I can drill out the bolt pattern myself..</end quote></div>
The '04 Predator rear rim is the same as the Honda rear end a 4/110. You can pick these up off of ebay cheap or new from Rocky Mountain ATV for less than $50. Or you can go to Predatorowners.com and go to the classified section there and pick up some OEM Predator rims there.
Old Nov 29, 2008 | 07:59 PM
  #33
linko013's Avatar
Thanks a lot.. I wasnt aware that Honda has a compatable rim for the pred.. Would you be able to do an ebay search real quick or an example of what to search for on ebay for? Thanks a lot.. In the mean time Im going to check out Predatorowners.com
Old Nov 30, 2008 | 10:30 AM
  #34
Kerbbirds's Avatar
Get a multi meter and see if its charging, should have 14 to 14.5 volts at the battery while running a little over idle, if not its probably the regulator
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
