2000 honda 450
Old Nov 22, 2008 | 10:11 PM
Sisco1957's Avatar
Default 2000 honda 450
Does anyone know what the switch controls on a 2000 Honda 450 Foreman ES. The switch is on the left handlebar and activates when You shift into reverse.
Old Nov 22, 2008 | 10:33 PM
cherokee99's Avatar
you mean the revers button? you push in, hold the break and shift into neutrail?
Old Nov 22, 2008 | 11:05 PM
HondaMechanic's Avatar
It won't let the shift drum turn past neutral so it won't go into reverse by mistake while still moving forward ..
Old Nov 22, 2008 | 11:27 PM
Sisco1957's Avatar
This is an switch with 2 wires. It is under the left brake lever. The plastic part that the reverse cable hooks to activates this switch when you push the button in and pull the lever . Thanks.
Old Nov 23, 2008 | 01:23 AM
cherokee99's Avatar
its an electrical saftey thing for your reverse
Old Nov 23, 2008 | 07:59 AM
Are you in Canada .. ? .. That sounds like the brake light kits we had to put on Hondas between about 2000 & 2003 ... does your bike have aftermarket brake lights , the 450 used a single square light on the right side of the trunk...
Old Nov 23, 2008 | 11:28 AM
Sisco1957's Avatar
No, I'm from Texas. I looked at a wiring diagram that HondaMechanic has on here. I think it is the reverse shift switch that grounds to the ECU when the reverse cable is pulled. I'm guessing it completes the circuit to allow the electric shift go into reverse. Thanks for the help and all the replies. Have a nice day.
The reason for all the questions was my neighbor was replacing the bracket on the left brake lever. He mistakenly ask for the part for a 2001 and his is a 2000 model. The new bracket has no mounting holes for the switch and we thought it might be a brake light switch that we could leave off. Thanks again.
2007 Grizzley 450
Aug 13, 2015 06:33 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Aug 6, 2015 03:59 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
