01 sportsman 400 elect issue
Old Nov 22, 2008 | 10:44 PM
G8TR FAN's Avatar
Default 01 sportsman 400 elect issue
Today while riding I lost all power, nothing works at all. no lights, starter, nothing. I see there is a 20 amp circuit breaker on my wiring diagram. Where is it??? cant find it.
Old Nov 23, 2008 | 07:34 AM
In black sealed pouch in front of battery behind side panel.Can use a test light to see if 12 volts on wires on either side,if not then themal fuse probably corroded. They are designed to shut off and reset,but can go bad also. This is the 20 amp main fuse(thermal fuse) that provides power to ignition,speedo,etc. If shows current on one side only,slice pouch and check connections,also can jump leads to see if power then goes to speedo,etc. Easily replaceable part,comes with sealed pouch and wires to splice back in. Also should be another fuse under front panel that controls fan,lights,etc.
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Shifts
Jul 3, 2015 07:59 AM
