97 500 XPLORER REAR BRAKE ROTOR REMOVAL
Old Nov 24, 2008 | 09:59 PM
thestroker05's Avatar
Default 97 500 XPLORER REAR BRAKE ROTOR REMOVAL
I need to know how to remove the rear output shaft brake rotor on a 1997 500 Xplorer. I have the caliper off and I was needing to know do I need a wheel puller to remove it. If someone could tell me how to do it, I would really appreciate it. Thanks in advance for your time.
Old Nov 25, 2008 | 08:59 AM
After removal of the 3 bolts,the center hub comes out(may be rusty,frozen). Its a tapered fit and may have to use a small puller,then the floating hub and disc come off together. IF your just replacing pads,I would just leave alone,unless replacing rotor because of warping,damage,etc.
Old Nov 25, 2008 | 11:24 AM
My rotor is broken lose from hub......looks like rivets could be worn out. is this possible. thanks mike
Old Nov 25, 2008 | 11:52 AM
Not uncommon for early 97 rear brake "floating pins" that secure rotor to hub to break or come loose. Replacement pins have been up dated to stronger bolts. You may have enough clearance to replace bolts without removing hub assembly? Been a long time since I've had a problem on any! OR hub may have to be removed along with rotor. If replacing bolts remember to loctite(red or blue) into hub. Good luck
greg74
Sep 10, 2019 03:03 PM
Sandman2.0
Jul 21, 2015 09:03 AM
ghost civic
Jul 19, 2015 10:13 AM
timster911
Jul 13, 2015 01:57 PM
tporath
Jul 11, 2015 12:31 PM
