400ex hesitating
Old Feb 4, 2001 | 01:31 AM
BLC's Avatar
BLC
my quad idles fine and runs fine except for one thing.... when i run 1/2 to full throttle for at least 10 min and come to a stop and put it in neutral, ill give it some throttle and it hesitates if i cut it off and leave it off for about 5 min and come back out and crank it up it wont hesitate at all.... it also blows out a lil puff of black smoke when it coughs.... any suggestions or anythinga at all will be appreciated thanx
Old Feb 4, 2001 | 10:42 AM
BLC's Avatar
BLC
i hear it may be because of rich jetting.... well if so what do i need to do.... but what i dont understand that if it is rich y wont it hesitate if ive just been riding casually and not heavy on the throttle? thanx
Old Feb 4, 2001 | 07:10 PM
3o0eXpAuL's Avatar
Yeah it is most likely the jetting.
The same thing happened to me 300ex after i got my white brothers on it had a hesitation so i jeted it , yesterday it was runnin rich cause of the weather change so today i took all my plastic off and my gas tank off because i had to adjust my valves then when i was done that i rejeted it to a 128 then it ran fine.
Old Feb 5, 2001 | 11:25 AM
BLC's Avatar
BLC
what exactly do i need to adjust to cure this problem.... it cant be the main jet because it runs fine 3/4 to full throttle but what about the needle, pilot or anything like that.... someone said that i needed to lean the pilot jet but i dont think thats it but im not sure could the needle be in the wrong position/clip
Old Feb 5, 2001 | 03:44 PM
Trxoutlawz's Avatar
what setting is the clip on the needle now? What mods if any are you running?
Sounds like you may be a bit rich in the midrange, that would be the needle setting..
Let us know....
Old Feb 5, 2001 | 04:05 PM
BLC's Avatar
BLC
i dunno exactly what clip position its suppose to be on everyone has told me it should be on 3 so im hoping its not on 3 so that way i know what the problem is coming from im getting it serviced this saturday so ill tell them to check that out
hueby
Nov 6, 2015 11:34 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
