Trail boss 250 carb
Old Nov 26, 2008 | 01:20 AM
dude_5024's Avatar
Default Trail boss 250 carb
I have a 1988 trail boss 250 that i have been working on, but cant figure out why fuel keeps leaking out of the carb. I have put a new needle in it and it still leaks.
Old Nov 26, 2008 | 06:30 AM
If float arm worn or set too high,can leak also.Can also set float arm to shut fuel off a little quicker by bending float tang down slightly. Hold carb upside down with float arm installed to see if level with carb body Or just a little higher by bending tang down. This might help solve leaking.Also is carb gasket new?
Old Nov 26, 2008 | 07:11 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just dont bend it too much or you might run out of gas going up a hill that i've seen it done lol.
Old Nov 26, 2008 | 01:19 PM
dude_5024's Avatar
The fuel is leaking out of the air box side of the carb. I cheched the floats and the arm they are set the way they are suppose to be. I had the carb in with everything hooked up except for the throttle valve slide and the needle were out and it didn't leak any fuel until i put the throtle valve back in. Then fuel just started flowing out of the back sie of the carb.
Jmuddin284
Jan 19, 2026 07:16 AM
Robbbb55
Jul 8, 2015 02:11 PM
tweeder
Jul 5, 2015 01:57 PM
Mikea1978
Jul 4, 2015 12:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
