Warrior won't start won't move in gear
Old Nov 26, 2008 | 06:35 PM
martyMusto's Avatar
Default Warrior won't start won't move in gear
Hello,
I have a 1999 Warrior which is experiencing some problems.
I noticed a few weeks ago that the starter was sounding 'clunky' when I was attempting to start it. Finally it gave out and now it's impossible to start it using the electric start.
Today I replaced the battery, to no avail.
I can't shift the bike into 2nd gear.
It can freely shift from 1st to neutral though.
The rear wheels lock up when it's put into first gear. They only move a touch. What could be the problem?
What should I check first?
-Marty
Old Nov 26, 2008 | 09:02 PM
91Warrior357's Avatar
pull the stator side cover off and check out the starter clutch, hopefully the motor iteslf isnt locked up
Old Nov 26, 2008 | 10:31 PM
martyMusto's Avatar
I finally got the thing in gear past first, and it's rolling with resistance as it should when in gear.
I pulled the starter and took it apart. The thing is packed full of carbon deposits.
I will clean it tonight and test it tomorrow after I've eaten a ton of food.
Hopefully I can get this thing started.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
alix
Jun 28, 2015 03:28 AM
Nelson
Jun 20, 2015 01:59 PM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
1000gade
May 27, 2015 12:37 PM
