01 sportsman 400 Issues
I had posted before about some Electrical issues I was Having loosing spark, and thanks to all that applied, I found the loose connection was my ignition switch was going bad. Thanks again! I have a different issue now, After running awhile and getting to opperating temp it will just die. I know it is fuel related because I confirmed spark was present. I have a new fuel pump and I am installing it in the morning. If that does'nt fix it what else could it be? I am guessing it would have to be the carb, cause I cannot figure anything else it could be. Have any of you seen this before??? If I wait awhile Broooooom cranks up and runs for awhile, then more of the same. Any suggestions are appreciated.
KimSJoh
14
Jul 18, 2015 07:20 PM
