standing honda recon
Old Nov 30, 2008 | 09:56 AM
Hawkman300's Avatar
Default standing honda recon
ive got an 05 recon. if im doing wheelies and i stand it up towards the sky on the back bumper, are there any problems with this as far as the engine and carburation goes? any help is appreciated!
Old Nov 30, 2008 | 10:54 AM
hondarider94's Avatar
umm well on mine if u do it straight up in the air and ride it it will shut off the overflow tube with puke out gas
Old Nov 30, 2008 | 03:23 PM
SuziOzark's Avatar
Same here, my overflow tube drains out some gas on my Ozark 250 and the same thing happens on my friends Mojave 250.
Old Nov 30, 2008 | 08:18 PM
cherokee99's Avatar
if you dont turn off the fuel the fuel in the carb will drain into the cylinger, if you do this for a long time you get alot of gass in your oil
Old Dec 1, 2008 | 12:04 AM
Hawkman300's Avatar
so wen u say overflow tube u mean the tube that is on top of the gas cap? and what if it shuts off wen u do that and i get off and let it sit there, is that OK?
Old Dec 3, 2008 | 12:10 AM
cherokee99's Avatar
it can ether spit gas out the carb overflow or the gas cap overflow, or both. TURN OFF THE GAS otherwise you could just drain fuel strait into the cylinder and thats no good
Old Dec 3, 2008 | 07:38 PM
Hawkman300's Avatar
ok, i understand the fuel spitting, but will that only happen if the engine is still running at a 90* angle?
and when you say turn off the gas, do you mean shut down the engine or turn fuel valve to OFF?
peytonius
Sep 28, 2015 02:18 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Steeldon
Sep 8, 2015 10:51 AM
DGNAZ
Sep 5, 2015 09:14 PM
Hondamx751
Aug 13, 2015 01:06 AM
