06 700 EFI stalls while winching
Old Nov 30, 2008 | 10:46 PM
kodiak 450's Avatar
Default 06 700 EFI stalls while winching
Used my Polaris 2500# winch for the first time today and when I put a hard pull on it my 2006 700 EFI Stalled. I was keeping the RPM up and it stated to run rough and then stalled. I could not get it to start again until I jumped it with my tractor. It would turn over but not start. The Battery voltage on the dash read 11.6 volts. Any Ideas?
Old Nov 30, 2008 | 11:13 PM
upnort's Avatar
Sounds like the battery is not taking / holding charge. Battery should be over 14 volts at high idle. & should also hold plenty of charge to winch. Would change out battery.
Old Dec 1, 2008 | 07:23 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you used the winch and lights or what have you alot then it kill drain the battery and the charging system will not keep up w/ it. the bike needs around 12.5 volts to keep running hence it ran like crap and then died.
Pehter
Oct 3, 2024 11:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
chewy78
Sep 8, 2015 10:37 AM
