1998 400 polaris 4x4 will not go into high or reverse?
Old Dec 3, 2008 | 02:40 PM
mikesbikesmalden's Avatar
Default 1998 400 polaris 4x4 will not go into high or reverse?
no high no reverse at all. low works fine got any ideals? linkage is working i tryed prying it back and forth with wrench it does not help. just looked at it again the motor has dropped down and the clutch has rubbed a hole in the cover i pryed the engine back and up and reverse works now but it will no go into high or low must be bad motor mounts????
Old Dec 3, 2008 | 03:33 PM
Groovy's Avatar
sounds like you lost a bolt on a motor mount and the motor has shifted.
Happened to my sons elcheepo china made quad as well... onlt the drive shaft came loose and disengaged.
Old Dec 3, 2008 | 03:54 PM
no bolts missing motor mount mounts are worn but i acts like something in the transmission
Old Dec 3, 2008 | 03:59 PM
Groovy's Avatar
The mounts would have to be pretty damn worm to make the whole engine shift. Sorry I was of no assistance. Good luck!
Old Dec 3, 2008 | 04:12 PM
TLC's Avatar
TLC
Take the rods from shifter to tranny off the tranny end, grap the tranny lever with large vice grips and see if you can get all 3 gears, if so you can eliminate the tranny as the problem.
You could also take the rods off the shifter end and just grab the two rods by hand and push/pull them to see if the tranny works all 3 gears.
Old Dec 3, 2008 | 04:15 PM
i took them off and pryed them with a wrench still the same the rubber mounts are worn pretty darn bad
Old Dec 3, 2008 | 04:29 PM
TLC's Avatar
TLC
Well sounds like a Tranny issues then,because it should go into gear by the above method even if the gearcase was on the ground,on a bench or in the ATV. The worn mounts are just job #2.
Old Dec 3, 2008 | 11:08 PM
drlang's Avatar
It's the transmission, you need to make a decision. Either have hi or reverse, I opted for reverse for plowing, now I have lo and reverse. Common issues for that vintage the forks get worn and won't hold it in hi anymore. Adjust the linkage to at least get it moving again. Good luck Doc
Old Dec 4, 2008 | 02:17 PM
im pilling it off right now its acting crazy it was just hung in reverese could not get it out for nuttin so i started pulling it out i had to heat and beat the rear clutch off and now it shifts high/low and will not pop into reverese i will post the problem later today thanks
Old Dec 10, 2008 | 12:38 PM
ok so i found what the problem was the high/low shift fork was broke off and jamming the gears it was jumping around and thats why one time it would hit reverse then ride it and next time only low. shift for was only $120.00 list at don and roys works fine now thanks
Jmuddin284
Jan 19, 2026 07:16 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
jettman
Jul 6, 2015 12:16 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
