Battery Light
Old Dec 4, 2008 | 02:21 AM
chevyman142000's Avatar
Default Battery Light
Hey guys, just wondering if any of you have run into this or not. I was out in the first snow the other night pulling my sisters around on sled behind the wheeler. While doing so, I had the low beam headlights on, the handwarmers on, and the rear work lights on. When the wheeler would sit idling for a while, I noticed the battery light came on flashing. As soon as I revved it a bit, the light went off. You think I should worry about this at all? Or do you think that is just a pretty big drain on the battery and is normal? BTW, this is on an 08 800. Thanks in advance!
Jeff
Old Dec 4, 2008 | 07:11 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you had too much on for the charging system to handle at idle this is why the light came on. i think just the handwarmers take alot of juice i would guess.
Old Dec 4, 2008 | 10:53 AM
02magnum500's Avatar
Gets his share of deer.
I agree with the work lights, tail lights, headlights, handwarmers, pod, and most likely the cooling fan, it draws on the charging system at idle. I wish they had more "juice" at idle, but the watts are not enough at idle. Even when on the throttle riding and the fan kicks on I can see the headlights dim a bit.
bzdok1234
30
Feb 23, 2016 01:55 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
