need some info
Old Dec 5, 2008 | 10:07 PM
1130all's Avatar
Default need some info
i just bought a clutch off ebay.i have a 99 scrambler 500 it is stock and i was wondering what you all was running on the secondary clutch settings.the clutch came with spring and weights the weights was "S" with a blue spring .is the weights better than the stock or just keep the stock setup .i would like to know the sencondary stock setting it is on 2-2 right know and it seems to have a higher rpm .thanks for any help
Old Dec 5, 2008 | 10:59 PM
ftwflh's Avatar
Stock 500 Scrambler clutching is 10WH weights blue/green spring.The S should have a number under it.
If you need stock 500 weights pm me.
buddieboy
Dec 9, 2016 05:50 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
greg86hd
Sep 16, 2015 12:32 AM
