Fuel Troubleshooting Help 07 500 EFI
Old Dec 8, 2008 | 04:00 PM
Beefcake35's Avatar
Default Fuel Troubleshooting Help 07 500 EFI
HI,
I have a 07 Sportsman 500 EFI that started up a bit ago and than died after I backed it out of the garage. Once it sat a bit (approx 5 mins) it started back up and died again. It will now no longer start unless I spray some ether into the air cleaner. We are expecting a bunch of snow tonight and I need it to plow my driveway. Also parts department closes in 2 hours. Any help is very much appreciated.
Just looking for the best and easiest way to troubleshoot this.
THANKS!!!!!
Old Dec 8, 2008 | 04:09 PM
lovmudd's Avatar
Sounds like you ran it out of fuel.
I wouldn't use anymore ether on it, I hate that stuff. I don't know what your weather is like there, but my first guess would be a fozen line, preventing it from getting fuel.
If this is the case, I would try getting it into a warmand cozy place to thaw it out and then add some de-icer to the fuel to prevent it from happening again.
Can you hear your pump running when you turn on the key?
Old Dec 8, 2008 | 04:12 PM
Beefcake35's Avatar
Thanks for the quick response.
The Tank is full of fuel
Its in a garage that is heated to 52 degrees so I dont think the lines are frozen. I can hear something turn on when I turn on the key. It runs for a couple seconds.
THANKS!!!!
Old Dec 8, 2008 | 04:30 PM
Beefcake35's Avatar
Let me take that back, when I turn the key on it buzzes for about a second. and than buzzes for a couple seconds when I turn it off
Old Dec 8, 2008 | 05:58 PM
lovmudd's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Beefcake35
Let me take that back, when I turn the key on it buzzes for about a second. and than buzzes for a couple seconds when I turn it off</end quote></div>
Well, I guess you can rule out a frozen line. Someone else will have to jump in and help with the EFI.
Is the buzzing you hear the same, as you have always experienced, when turning on the key to start it? Or is it a different sound.
I guess I am asking you if you are hearing the fuel pump, pumping up to pressure the system. On mine, it is quite distinctive and I am used to hearing it upon start up.
pgamboa
Dec 24, 2023 11:52 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Elkaholic
Sep 6, 2015 02:44 PM
