Gear oil in front diff. on 300 4x4?
Old Feb 4, 2001 | 10:33 PM
Frank300's Avatar
I had to drain the diff fluid in the front diff this weekend and was wondering if it is o.k. to use standard 80-90w gear oil or should I strickly use 80w as it states on the diff. case?
Old Feb 4, 2001 | 11:25 PM
BigRed450's Avatar
80-90 gearlube will be fine. Do not use synthetic unless it specifies for Limited-Slip differentials.
Old Feb 6, 2001 | 04:09 AM
trailboss450's Avatar
25 Year Member
Also remember to add some GM limited slip differential additive. If you don't you will develope a chatter noise in the front differential when turning.
coolguy420
Jul 10, 2015 01:17 AM
sara durrant
Jul 6, 2015 05:32 PM
jettman
Jul 6, 2015 12:16 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Mphillips
Jul 2, 2015 07:20 PM
