06 POLARIS 700 CUTTING OUT
Old Dec 10, 2008 | 02:07 PM
jasons060's Avatar
Default 06 POLARIS 700 CUTTING OUT
I JUST BOUGHT A 2006 POLARIS SPORTSMAN 700 EFI AND AT FULL THROTTLE @ ABOUT 35-40 MPH IT CUTS OUT BUT IF YOU BACK OFF THE THROTTLE TO 3/4 IT RUNS FINE. JUST WONDERING IF ANYONE HAS ANY IDEAS? THANKS
Old Dec 13, 2008 | 10:10 AM
Koerbs's Avatar
It usually helps to not type in caps lock, it tends to annoy some people, It makes it seem like you are yelling and none of us have the self esteem to handle that.
Being that your ATV is EFI it is harder to guess what it could be, might be water in the gas, old gas, might need a new plug, or something that the dealer must "plug in" to find.....
Old Dec 13, 2008 | 11:04 PM
lorigirl's Avatar
You've probably got a bad ground. Check where your grounds are connected to the frame. This happened on my 500 x2. It would cut out and pop and carry on. Found the ground screw loose. That cuts out the computer, etc and causes it to cut out.
Old Dec 13, 2008 | 11:43 PM
dodge33's Avatar
could be loose ignition connections, water in the fuel, low battery voltage, Clogged air filter, electronic throttle malfunction, or could just be lean or rich fuel! just a couple things to check. depending on age of atvm the injectors might need replaced or cleaned, that could cause high rpm/speed loss. also the electonic control unit (ecu) might need work (worst case scenario) and the dealer would have to help with that one!
Old Dec 14, 2008 | 08:42 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is it cutting out or back firing. water, bad ground tends to make them want to back fire.
Old Dec 14, 2008 | 01:43 PM
H20's Avatar
H20
The first thing I would suspect from your discription is the TPS sensor.
(Throttle Position Sensor)
Cole Hadden
Jun 15, 2025 09:05 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Gtsordo
Jul 13, 2015 10:38 PM
maxjung
Jul 13, 2015 05:11 PM
Shifts
14
Jul 13, 2015 08:41 AM
